suspension SW2
Old May 2, 2011 | 12:35 PM
schulznotee's Avatar
Default suspension SW2
Any of you guys done anything to raise front/rear of the S series? Except for a little more road noise that I'd like, the only gripe I have on my wagon is that, at going on 76 years, it's getting a little harder to get up out of it.
Any way to shim the coils or ...?
On a side note... I recently read of someone having to replace the ignition switch at 'bout 100K. Yesterday I couldn't turn the key in the switch and thought I had the same problem. Turns out that the KEY died. It was worn so badly that it wouldn't shove the tumblers into proper position. An AAA road locksmith cut a new key right in his Chevy HHR van and we were on our way.
Old May 2, 2011 | 09:17 PM
timmerz's Avatar
I feel you on the gettin' in and out of the wee beast...it's the only complaint I've got about mine also, and I'm right at 55...you're in MUCH better shape than I am, there's no way I'd still be in this ride at 76....congratulations! Doing anything to the suspension like shimming it to get it to ride higher would only ruin your ride, and I don't know if the trade-off would be worth it...I've never looked into longer shocks or raising the ride, so hopefully somebody with some good experience will chime in...
Occasionally I have to wiggle things around on the column around the ignition to get things to line up, and occasionally when I pull the key out of the ignition the spring-loaded thingy doesn't spring, and I have to poke the ignition slot to get it to spring out...it seems to be one of the weaker spots on the car...but so far this key continues to work....
Old May 16, 2011 | 05:54 PM
navypcc's Avatar
I found a slight fix for this issue. My 2000 SW1/SWP came with the factory 14" steel wheels and hubcaps. I found a nice set of alloy rims at the junk yard for $30 each and put a new set of tires on them and gained an inch in height. I needed new tires anyway.
Old May 16, 2011 | 07:29 PM
every little bit helps
Old Aug 21, 2012 | 03:20 PM
skooter's Avatar
Wouldn't it be easier to raise the seat? It would not effect the mechanics of the car.
Old Aug 21, 2012 | 09:50 PM
Timmerz and I are the same age. Until next Tuesday anyway. Then I'll be 56. Does your car have shocks or struts in the back? If struts, maybe a few of the old style rubber or aluminum spring spacers? I don't know, I'm just guessing.
Old Aug 21, 2012 | 10:50 PM
struts
Old Aug 22, 2012 | 03:27 PM
You can put larger tires on any size rim. Wheels don't make the car sit higher, changing the tire diameter does.
So is there a reasonable way to raise a car with four wheel independent macpherson struts? The answer is NO.
mtnbob
Feb 20, 2013 08:57 PM
98SL1
Nov 14, 2012 11:54 AM
gmb300
Feb 21, 2010 08:20 PM
kylebc
Sep 8, 2009 10:41 PM
swift25
Mar 20, 2009 09:51 PM
