stalling issues
Old Aug 6, 2011 | 11:52 AM
whitedog59's Avatar
Default stalling issues
My son's 1999 sl2 sedan has an issue thats's driving me nuts. car starts and runs well except after about 30-45 mins will stall and lose electrical power. guages go to 0 no radio intermittent weak chimes. Car can be push started and will run for a few minutes then stall out. Some missing noted. If it sits for a couple of hours it will restart with a jump and repeat the process all over. Battery checks out ok. Any suggestions?
Old Aug 6, 2011 | 03:15 PM
Your battery does not have a full charge -- either
the alternator is not going at full output and not fully charging battery, which will eventually drain and not be able to supply sufficient current to run the car.
Or
the battery itself may not be holding the full charge coming from the alternator --battery may have a cell going bad.
What's the voltage across the battery terminals with the car at rest (off) and what's the idling after startup (with no accessories turned on -- before the funniness)?
sdward
Apr 29, 2006 12:11 AM
jillowolf
Jan 14, 2006 08:51 AM
Erinb2626
Oct 4, 2005 04:41 AM
Erinb2626
May 25, 2005 09:19 PM
Terry
Mar 28, 2005 11:34 PM
