Sputtering when accelerating
Old Apr 24, 2007 | 03:18 PM
sborn9's Avatar
Yeah, I replaced the lower sensor. I haven't chaged the connector because I have no idea where the closest dealer is to get one.....I live in nowhere Southeast Kansas. Do the codes clear automatically? These codes I gave could have been in there for quite some time. The SES light only comes on every so often for a very short period of time. Thanks again.
Old Apr 24, 2007 | 11:11 PM
GarrenNatas's Avatar
They should clear automatically... To check, you should go to your nearest AutoZone (or equivilant store) and use there OBD reader. That will let you manually clear all your codes and then you will be able to see if they come back.
Old Apr 24, 2007 | 11:38 PM
change engine coolant temp (2 wire) sensor. Replace with brass style replacement.
Replace connector as well (Saturn only part---$10 -- just do it)
Derf
Ducky -- I would NEVER forget to mention the connector -- it was in my original post! Shame on you for not noticing[img]smileys/smiley2.gif[/img].
_____
Although the SES may go out, the I beleive the ODB I codes are retained
until cleared. Autozone may not have an ODB I scanner tool, so you may
not be able to clear the codes there......
Edited by: derf
Old Apr 25, 2007 | 01:09 AM
ducky's Avatar
[img]smileys/smiley18.gif[/img]I deserved that!? Maybe I can make it up to everyone by suggesting pulling the batteryground cable and pressing the brake pedal to erase the SES code stored in memory? The radio presets will be lost though. That's the best I can offer not being totallyfamiliar with the S-series.
Old Apr 25, 2007 | 12:14 PM
Oh that's right... That's OBD I... One of my old cars had that and it was such a pain in the *** to find a place that had a reader that I ended up buying one myself. The 200 bucks sounded like a good idea until I sold the car a couple months later. </span>[img]smileys/smiley5.gif[/img]
Old Apr 30, 2007 | 11:44 PM
sborn9's Avatar
Great new everyone. The problem was most definitely the timing chain. Replaced it this past weekend and all is well. The chain was so loose that it had skipped a couple teeth......it was probably about an 1/8 of a turn out of time (cam sprocket at about 1:30 when the Crank sprocket at TDC). Anyway, I appreciate all of the help. I did change the ETCS and it obviously needed it because I looked at the old one yesterday and it was cracked.
Old May 1, 2007 | 05:20 AM
Hey ducky or derf:
Any chance that the timing chain could be a cuase for me rough acceleration? It's bad enough that it will even knock the cruise control off when I go to accelerate by using the button on the steering wheel...
Old May 1, 2007 | 08:01 AM
ducky's Avatar
Year and mileage?
Old May 1, 2007 | 07:32 PM
97 SC2 with 134k miles on it...
But I was looking at it last night and I noticed that my passenger side motor mount is thrashed... I'm thinking I found my problem...
drakedad3
Mar 4, 2019 09:37 PM
racingross11
Apr 2, 2011 08:12 AM
jimmyslide
Nov 20, 2008 09:10 AM
Itsnotme1988
Apr 25, 2008 07:23 AM
imaukfan
Jan 5, 2007 10:01 AM
