Something that scared me
Old Mar 12, 2006 | 07:36 PM
euroc's Avatar
I just changed out my spark plugs on a 93 SL and found oil in two of the cylinders[img]smileys/smiley11.gif[/img]!!! Does anyone know if that suggest a bad oil seal on the piston? On number 2 it was so bad that the oil was inside the spark plug shaft. It was black oil, so I dont think it was just a spill, but is it possible for oil to seep into the shaft? Let me know if you know.
Old Mar 13, 2006 | 04:58 PM
ottjoe88's Avatar
sl1 or sl2
Old Mar 13, 2006 | 05:17 PM
euroc's Avatar
sl1 twin cam
Old Mar 14, 2006 | 01:32 PM
euroc's Avatar
Any ideas ott?
Old Mar 14, 2006 | 05:40 PM
ottjoe88's Avatar
if it is a twin cam then it is a sl2, and you just need to get a new gasket
Old Mar 14, 2006 | 07:19 PM
euroc's Avatar
You were saying there is an inner and outer? Can you give me some tips on changing, etc?
Old Mar 16, 2006 | 03:32 PM
ottjoe88's Avatar
remove the valve cover and if i recall the 91-94 use liquid gasket around the spark plug wholes, so clean the surface and put on some liquid gasket, then replace outer valve cover gasket
Old Mar 16, 2006 | 06:30 PM
euroc's Avatar
Okay, so I just take off the valve cover by pulling the plug wires and removing the dozen or so bolts around it? Are there any tricks or surprises I will run into when I do this? (Sometimes it just sounds TOO easy)
Old Mar 29, 2006 | 02:21 PM
94sl2's Avatar
haha, wow, a twin cam sl1, thats odd...you sure you replaced the spark
plugs the right way because if you think that you have a twin cam sl1
then you are in serious car knowledge trouble
Old Apr 2, 2006 | 05:31 AM
euroc's Avatar
ha ha... maybe it was the drain plug in the oil pan. Or maybe a typo.
crimsonandblue
11
May 24, 2013 07:51 PM
Johnny.B
Feb 2, 2013 11:06 PM
Octavious
Aug 2, 2012 06:10 AM
cartunez2004
Jan 19, 2010 11:35 PM
vip3r87
Feb 9, 2009 09:05 AM
