sl2 94 twin cam. automatic
Old Aug 20, 2008 | 06:11 PM
Rogger's Avatar
any suggestions
i have a 94 sl2 was running great until the idling started reving on its own...fluctuating up and down.
what i did - cleaned and checked all throttle body parts..sensor, inlet air valve all checked out okay...end result after cleaning throttle valve and air inlet valve = car now stalls as rpms drop right down and i need to hold the gas to keep them up or it flutters and dies on me
also, not sure why but engine cooling fan always comes on even when i turn on the car, plus i can''''t read codes because no engine light comes on, even with these problems and jumping b-a terminals to get codes??
any ideas - get new pcm???
checked all components and all looks good - reference voltages, range voltages.
any help would be great...any contact tosecond handpcm''''s too?
thanks
rog
Edited by: Rogger
Old Aug 21, 2008 | 09:00 AM
Low Saturn's Avatar
Coolant temperature sensor. You car has two, replace the two wire one.
Old Aug 21, 2008 | 09:11 AM
Rogger's Avatar
thanks there mike...will give it a shot
Old Sep 3, 2008 | 08:03 AM
l3m0nZ's Avatar
just pump the egr valve about 4-5 times usually it stops or-else just change the egr valve..
Old Sep 10, 2008 | 05:19 PM
Rogger's Avatar
thanks...appreciate it
NMRAmustangracer
May 26, 2014 02:19 PM
Willthrox
Oct 13, 2010 09:04 PM
imalert
Feb 22, 2009 06:55 PM
MINICooperS
Apr 22, 2008 08:59 AM
Bobcat698
Mar 9, 2007 08:00 PM
