The SKY IS FALLING! (Ceiling actually!!)
Old May 24, 2009 | 05:59 PM
cahaldo's Avatar
Default The SKY IS FALLING! (Ceiling actually!!)
My SL1 Ceiling is falling down. the cloth is separated from the backing. I tried spraying glue into it, but it came right back down. Any clues or methods to get it back up where it belongs. It's also happening on my Ford Ranger. Same cloth over foam board as in the SL1.
HELLP!!
Snidely
Old May 24, 2009 | 07:03 PM
First you must clean the items you want to glue....then use 3M Hi-Strength 90 Spray Adhesive
Old May 25, 2009 | 06:50 AM
indeed -- they actually make headliner adhesive - I have used it for things other than headliners and I'm pretty sure you could glue fur to one of those bald cats with it (no, I have NOT tried this nor do I advocate such practices)
Old May 25, 2009 | 12:16 PM
cahaldo's Avatar
Would you recommend that I take it down and remove it from the car to do this?
-Snidely
Old May 25, 2009 | 02:53 PM
I'd take it out, it's purdy easy to do.
Old Jun 24, 2009 | 12:07 AM
jlannigan's Avatar
I took my headliner out, it wasnt exactly a snap, but all things considered, it was one of the easier tasks.... New headliner material can be fairly pricey, but it seems to degrade with heat/humidity.
Also to get the trim off no special tools are needed and you can work it out the passanger side door. I highly recommend the old gorrila grip to get the molding out from the interior, and dont bother taking the seat belts mounts off, just slide them all the way to the bottom, should give you enough wiggle room.
Old Jun 24, 2009 | 06:27 AM
glad it worked out for ya. Also, thank you for posting the pointers for others who come along.
Eric108
Sep 13, 2016 04:16 AM
OnyxSkyBabe
Dec 27, 2007 06:04 AM
beckmaster
May 9, 2007 10:19 PM
richm
Jul 25, 2006 03:46 PM
sunguy7
May 1, 2006 12:01 PM
