Revs stay up between gears
Old Jan 6, 2010 | 02:56 PM
SaturnJeff's Avatar
Default Revs stay up between gears
1999 SL1 5-sp. When I'm shifting, the engine actually revs a little higher between gears, instead of dropping. When I am at a standstill, it idles normally. I've been told everyting from a clutch to a vaccum leak. Help!
Old Jan 6, 2010 | 03:51 PM
leejm12's Avatar
I just swapped an SOHC engine in a 95 and replaced the clutch and now have that problem. Suspect it isn't the clutch, and more likely a vaccum leak. But I have the same issue. 1 week now and haven't found the leak. Keep me informed. -J
Old Jan 6, 2010 | 07:01 PM
throttle body been cleaned?
Old Jan 7, 2010 | 04:37 PM
leejm12's Avatar
Nop. But I will give that a try. Thanks, -J
Old Jan 9, 2010 | 05:20 PM
ripperpabs's Avatar
i have 95' SL1 5spd that also has this problem, i have tried cleaning the throttle body, cleaning then replacing the pcv valve, and also replaced some older vacuum hoses. but the car still revs between gears. any other recomendations?
Old Jan 9, 2010 | 10:17 PM
IAC been cleaned?
Old Jan 10, 2010 | 10:54 AM
ripperpabs's Avatar
yea i cleaned when i removed the throttle body but never replaced. what is the best way to test that its operating properly? i also forgot to mention that i recently replaced the TPS too.
Old Jan 10, 2010 | 03:59 PM
you're makin it harder to diag by leaving out key info......but whatever.....
vacuum leak?
spray some throttle body cleaner around the outside of the throttle body and around the intake manifold gaskets on a COOL engine and listen for changes in rpm to find your vacuum leak
Old Jan 13, 2010 | 11:30 PM
92SL2's Avatar
some car manufacturers made cars do that for smoother shifting.
Old Jan 14, 2010 | 03:39 AM
indeed but the old s cars do not rev match....
