Replaced Timing Chain Can Won't Start
Old Oct 19, 2010 | 05:19 PM
paulruiter's Avatar
Default Replaced Timing Chain Can Won't Start
We replaced the timing chain in our 1999 SC2 (twin cam) and were very careful not to move the top or botom sprockets. When we tried to start the car after re-assembly, it tried to start, but would not. I check for spark, it was good. Removed two plugs, very dry, so added some gas directly into the engine, again nothing. Waited 5 minutes tried again, weak sign of firing, but nothing. Seems one of the cams is off, but not sure. I'm very good with small block chevy's and pontiac's, but this is the first real work done on a saturn.
Please advise
Old Oct 19, 2010 | 09:31 PM
Small Block Chevy's and Pontiacs when you replace the cam drive belt, the camshaft sits right over the crankshaft in the middle of the engine, it is a simple as aligning the two (generally) spots on the gears and indexing the chain according. Probably learned from reading the instructions and once done almost all V type push rod engines work the same way.
Which leads to the question
did you buy a book of instructions to do this with? You have to align both cams and the crank to index reference points and just taking it apart will cause it to move by itself.
So
having put things like that together wrong even with the instructions and they don't start or run very well when that happens, did you buy the instruction manual?
Cause if you did it is going to be a whole bunch easier to answer your question.
Old Oct 20, 2010 | 08:13 AM
paulruiter's Avatar
Here's a lesson for everyone, I have had a reference book for every car I have owned, except this one. Always get the book! We went last night and bought one, boy do I feel stupid. After working on cars, boats, snowmobiles etc for over 30 years I though I knew how to fix just about anything. WRONG! We are going to tear it back down and hopefully won't have to do a valve job.
Old Oct 20, 2010 | 08:35 AM
Don't feel bad, been there done that. Had a Mitsubishi with a timing belt on it. Required to replace it at about 70,000 or so. I put 3 of them on over the years. The third time I got it on wrong.
Yup, stupid wears well I guess.
Have fun.
If you have not heard loud crashing noises, you are probably o.k. usually when things get out of sync, a valve will first go through a piston and then bend.
The big fun alignment project came when I blew a head gasket and had to take the head off.
Boy howdy, a lot of alignment stuff to take into account on a twin overhead cam engine
tikidude
Aug 30, 2014 05:04 PM
Classof84
Jan 12, 2008 05:55 PM
redsaturn97sc2
May 19, 2007 09:21 AM
hartman
Apr 3, 2007 01:14 AM
hbtdawgs
Feb 8, 2006 05:39 PM
