Replace Timing Chain???
Old Aug 19, 2007 | 04:31 PM
Classof84's Avatar
I recall the dealer saying the timing chain should be replaced at 100,000 miles. Last week on "Click 'n Clack" (National Public Radio) they said do NOT replace chain unless it starts making noise. My SL has 95,000 and I am wondering what should I do.
Old Aug 19, 2007 | 10:03 PM
MINICooperS's Avatar
If it ain't broke don't fix it. I've got 190,000 on mine and never touched it. But then everyone has an opinion. Can't really fault the dealer for wanting to get under your hood. Guess he has to eat too.Edited by: MINICooperS
Old Sep 5, 2007 | 10:17 PM
chulew's Avatar
What happens when the timing chain goes on a 97 SL1? Major engine work required? I was quoted $700 roughly for replacing the chain before it breaks. I have a Ford Contour that had a timing belt fail and it was a lot to fix it and has never run the same. Nothing is wrong with the SL1. I uses a bit of oil but no leaks and no other complaints. I have 160k on it and no record of replaced chain. Does the chain always make noise before breaking? I only paid $1300 for the car so $700 is a lot but on the other hand, if it will run another 100k miles on a new $700 chain, it might be worth while. Any thoughts?
Old Sep 5, 2007 | 10:25 PM
Yep.............valves hit the pistons. Hey do it or don't do it, just no bitching either way
Old Sep 6, 2007 | 11:28 PM
Low Saturn's Avatar
If you are the original owner and have religously changed your oil and never let it run low, the chain should last over 200,000 miles. If the answer is no to any of the above, change it at 100,000.
"If it aint broke, dont fix it" doesnt apply here. A $200 timing chain kit and a few hours of time is better than several hundered rebuilding your engine.
Old Jan 12, 2008 | 04:41 PM
The Maertz's Avatar
Replace it....Trust me!!!< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-47";
urchinTracker();
Old Jan 12, 2008 | 05:55 PM
Low Saturn's Avatar
Your break??
alex_0227
Jan 27, 2010 09:30 PM
95_SL2
Jan 15, 2008 06:22 AM
95_SL2
Jan 6, 2008 09:51 PM
hartman
Apr 3, 2007 01:14 AM
hbtdawgs
Feb 8, 2006 05:39 PM
