Radiator and Heater Hose Clamp Replacement
Old Mar 9, 2024 | 12:51 PM
Aspenglade's Avatar
Default Radiator and Heater Hose Clamp Replacement
I'm replacing the radiator hoses and the heater hoses. A mechanic previously replaced the OEM clamps with the standard screw clamps, which has torn my radiator hoses. Can you all recommend an aftermarket hose clamp replacement with a part number? Or is there another car/brand/model from which I can source it from the junkyard?
Old Mar 9, 2024 | 08:31 PM
grcauto8453's Avatar
You want to get hose clamps from the junkyard?
Old Mar 9, 2024 | 10:57 PM
I don't believe the clamps used on the s cars were anything special.
If they are cranked down too tightly they may in fact tear into the hoses over time. The hoses may also become brittle and tear.
Just be sure you buy the right size so that the correct amount of tension can be applied without having to crank down crazily on the clamp
Old Mar 10, 2024 | 05:27 AM
Dude's Avatar
Old Mar 10, 2024 | 08:20 AM
Aspenglade's Avatar
Sure, why not? Same thing happened to my Camry. There was a gold mine of them in the pick a part. Replaced a few without issue. Also, you can use Highlander clamps for Camry too. So I'm asking the same for my Saturn. Figure, perhaps some GM model parts are interchangeable?
Old Mar 10, 2024 | 08:24 AM
Aspenglade's Avatar
Ok, thank you for your advice.
Old Mar 10, 2024 | 08:49 AM
You need to find someone else to work on your car or do it yourself. I've been working on my own cars for over 50 years and have NEVER had a screw clamp so tight that it tore into the hose. Someone doesn't know what they're doing.
Old Mar 11, 2024 | 05:48 AM
Dude's Avatar
Ya think........LOL!!
sldood
Apr 2, 2014 07:37 AM
mahans7
Jul 8, 2012 08:08 AM
edfromct
Jun 30, 2010 08:27 AM
Bing
Feb 3, 2009 07:49 PM
heather11787
Sep 17, 2008 06:03 PM
