Quick question: '99 Saturn SW2
Old Jan 5, 2013 | 03:35 PM
timmerz's Avatar
Default Quick question: '99 Saturn SW2
Will taking the positive lead off the battery for a couple of minutes and then re-hooking it clear any codes that have been thrown? I thinkI read that here somewhere but can't find it now...
When the radiator developed a crack the low coolant blink came on, and I had the radiator replaced, and coolant levels have been closely monitored, but still blinking...
Old Jan 5, 2013 | 10:35 PM
if it's the indicator for low coolant and your coolant in the reservoir is not low, the coolant level sensing switch located at the bottom of that reservoir is either gummed up or defective. You can remove the tank and try cleaning the sesnor.
Someone has posted how to best accomplish this...maybe Ocean..(?)
Old Jan 6, 2013 | 02:20 AM
timmerz's Avatar
Ah, thanks Derf....little project for next weekend....appreciate the info...
Old Jan 6, 2013 | 08:56 AM
or there is a wiring problem (can't rule out electrical gremlins)
Old Jan 6, 2013 | 12:58 PM
Disconnect the hoses from the upper and lower expansion tank fittings, and inspect them for signs of cracks or deterioration. Replace the hoses if necessary.
Remove the two mounting bolts holding the expansion tank to the side of the engine compartment.
Carefully lift the coolant expansion tank up, and disconnect the low coolant level sensor connection from underneath the tank assembly. Remove the expansion tank from the vehicle.
Pour the coolant into a container. Wash out and inspect the expansion tank for cracks and chafing. Replace if damaged. Ensure the low coolant level sensor operates freely.
Installation is the reverse of the steps shown above.
Old Jan 6, 2013 | 05:44 PM
timmerz's Avatar
Thanks a mil, OA...if I didn't have to work all weekend (yay, overtime!) I'd be following your instructions right now....as it is, hope to get time maybe in the middle of the week, after work one day...if not, next weekend, hopefully!
timmerz
Apr 21, 2014 09:58 PM
timmerz
Mar 31, 2014 02:33 PM
krazy Dan
Mar 21, 2013 09:37 AM
sam9787
Jun 2, 2011 08:09 AM
RaggedGlory
Oct 26, 2007 09:56 AM
