Power Window question
Old Jan 13, 2008 | 12:43 AM
LarryS's Avatar
I've got a '97 SC2 coupe (I wasn't sure if I should post this here or not seeing how I don't have a 3-door).
Anyway, the power windows work - most of the time.
However, sometimes they'll go down but won't go back up again. I find if I shut the ignition off and then back on, they're okay. Except I'd really like them to work all the time.
I figure I'll lubricate the tracks, but is there anything else I should check?
Thanks,
Larry
'97 SC2
Old Jan 13, 2008 | 11:31 AM
Low Saturn's Avatar
Start by removing the outter door panel and lubricating the tracks and gear. You also might need to remove the switch pod, open it up and clean the electrical contacts. If those two things dont work, replacement of the window regulator/motor assembly might be necessary.
TODDHENN
Oct 9, 2008 06:01 PM
zilla24
Sep 2, 2008 11:59 AM
bigbeat
Jun 9, 2008 11:56 PM
LarryS
Jan 19, 2008 09:44 PM
Fireball69
Jul 28, 2006 06:49 PM
