oil leaking into spark plug holes
Old Feb 15, 2009 | 11:03 PM
dtone90's Avatar
i have a 97 sl2 there is oil in the spark plug wells i dont know whats wrong i changed the valve cover and it still leaks what is wrong Edited by: dtone90
Old Feb 15, 2009 | 11:30 PM
Probably overtightened the cover.... adhere to torque specs.Edited by: derf
Old Feb 15, 2009 | 11:31 PM
dtone90's Avatar
but it was leaking before to and it was the stock cover
Old Feb 15, 2009 | 11:37 PM
Low Saturn's Avatar
Replace the gasket with a new preformed gasket and only use RTV in two small dabs where the timing chain cover meets the head. Then torque the bolts in the proper sequence to the correct torque.
Old Feb 15, 2009 | 11:39 PM
So the original gasket failed after12 years I''d say you got your money''s worth out of the original.
Did you ensure that both the head and the cover surfaces were clean and free of previous gasket material?
Old Feb 15, 2009 | 11:41 PM
dtone90's Avatar
yea i did im going to look at it tomorrow maybe i did miss something
Old Feb 15, 2009 | 11:46 PM
Low Saturn's Avatar
Just remember that having the bolts too tight is just as bad as too loose.
Old Feb 27, 2009 | 07:53 PM
MINICooperS's Avatar
If it''s just oil in the spark plug wells I''m betting you just didn''t use enough RTV in the circular valve cover grooves that surround the wells when installed. I wouldn''t skimp on the RTV at these locations. When you pull the cover it will be easy to see where the oil leaked from.
Signed,
BeenThereDoneThat
02saturnsl1
Dec 12, 2013 07:38 PM
krazy Dan
Jul 17, 2013 11:35 PM
kbankovi
Oct 21, 2008 07:06 PM
hartman
Jun 16, 2008 10:44 AM
Turbochump
Dec 9, 2006 01:25 PM
