Nocking noise when AC is turned on
Old May 18, 2009 | 12:53 PM
1999_Saturn's Avatar
Default Knocking noise when AC is turned on
I have a 99 Saturn SL2 that has a Knocking noise when I turn on the AC. When I turn off the AC, the Knocking noise is gone. Any Ideas?
Old May 18, 2009 | 08:52 PM
Hood open engine running A/c off look at the tensioner belt
While your still looking at the tensioner and belt have someone other then you turn the A/C on.
Whats the tensioner and belt doing now?
Old May 20, 2009 | 12:43 PM
When the AC is turned on, the belt tensioner pulls about half inch and the belt seems jumpy.
Old May 21, 2009 | 10:39 PM
turbokid's Avatar
sounds like a locked up compressor. If you have mechanical ability slip the belt off and give the a/c compressor a turn. If the clutch is catching or completely locked up then you will need a new compressor.
Old May 22, 2009 | 06:45 AM
Sounds like a good place to start -- keep us informed of your progress.
Old May 22, 2009 | 09:11 AM
It was the belt tensioner. I replaced the tensioner and the noise went away. This forum is great and thanks for all your input. Thanks sw2cam!!
Old May 22, 2009 | 09:47 AM
Great! Besides, tensioner assemblies are a darned sight cheaper than A/C compressors
uncljohn
Saturn Relay
Oct 23, 2013 08:32 AM
jcoll72305
Jan 24, 2013 09:45 AM
lizzyp
Feb 3, 2011 11:34 AM
