no spark???
Old Jun 9, 2009 | 10:51 AM
slaturn's Avatar
Default no spark???
Ok...I have a 1992 sl2 5-speed that I just swapped the trans from a 1994 sl2. Before the swap I had intermittent starting problems remedied by removing the coils/module and then reinstalling them, which worked. Now when I try anything it just cranks but won't start. I replaced the cps and the ects and still won't start...any ideas are greatly appreciated
in case it helps...I removed the a/c system and deleted the power steering pump, also I made a ground for each coil pack, because i thought that could have been the problem.
Old Jun 9, 2009 | 11:07 AM
Curiousity forces me to ask -- why delete the power steering pump ???
Old Jun 9, 2009 | 11:17 AM
slaturn's Avatar
I deleted the pump because it didn't work previously and it was simple to remove and I was ok with the lack of power steering...any ideas on my actual problem though?
Old Jun 9, 2009 | 11:21 AM
Well, I asked because there is a pressure switch associated with the power steering that sends a signal back to the Powertrain Control Module (PCM)
Old Jun 9, 2009 | 11:30 AM
slaturn's Avatar
Ya I saw the sensor on the resevoir...could that create a no spark situation? I would just think it would throw a code of some sort
petes343434
Feb 15, 2020 10:51 AM
hartman
Jun 16, 2008 10:44 AM
mathieuhouston2
Jan 27, 2007 10:24 AM
Turbochump
Dec 9, 2006 01:25 PM
hierophant
Aug 31, 2006 01:21 AM
