no spark???
Ok...I have a 1992 sl2 5-speed that I just swapped the trans from a 1994 sl2. Before the swap I had intermittent starting problems remedied by removing the coils/module and then reinstalling them, which worked. Now when I try anything it just cranks but won't start. I replaced the cps and the ects and still won't start...any ideas are greatly appreciated
in case it helps...I removed the a/c system and deleted the power steering pump, also I made a ground for each coil pack, because i thought that could have been the problem.
