Loose air filter assembly
Old Nov 24, 2024 | 08:38 PM
nascar girl's Avatar
Default Loose air filter assembly
MY 2002 Saturn SL2 is making a rattling whoosh noise I opend the hood and noticed the air filter assembly is missing a screw and its loose and rattling ts also stalled randomly would that cause it too stall???
Old Nov 24, 2024 | 08:49 PM
I doubt the loose air filter cover is responsible for the stalling, especially if the air intake tube is still connected to the front of the box and the ducting that includes the top of the airbox is still clipped and attached to the bottom of the box. If it's not, open the air filter box and make sure no critters built a nest in there or the tube which would block airflow.
Old Nov 24, 2024 | 09:48 PM
thanks I don't know anything about cars but I noticed its loose I would think that is the rattling I hear is the front supposed to be attached to anything or the air just goes out of the car I mean like a pipe or a hose its not connected to anything there is a hose connected to the engine and the assembly then another hose that does not connect to anything
Old Nov 24, 2024 | 09:49 PM
hi its not a loose cover the 2 bolts that attach to the engine one is totally gone so the entire assembly is rattling and loose
Old Nov 24, 2024 | 10:49 PM
Rootmazur's Avatar
Yep that will certainly cause a noise but it not likely to be the cause of any stalling.
Old Nov 24, 2024 | 11:23 PM
hi i was hoping maybe that was it at least I can fix the rattle I read you can even use a plastic twist to hold it down its been a decent car since I bought it for a 2nd car around 10 yrs ago but last few yrs lots of problem it was a hassle and a lot of $$$ to get it to pass emissions the light has been on forever time to get rid of it 164,000 miles on it
Old Nov 25, 2024 | 12:48 PM
Rootmazur's Avatar
I'm glad the car has been good to you for so long. It's very common for older vehicles to accumulate small issues over time, even as they remain drivable. Eventually though, they do oftentimes require some love and attention to keep them going strong. Here on this forum you'll find plenty of guidance and assistance to help identify and fix issues with Saturn vehicles. The more information and details you can provide, the better.
When Saturn vehicles were sold new, they typically had a maintainence schedule that was planned out to 175,000 miles. You said your vehicle has about 164,000 miles, so it likely has a lot of life left, even if it hasn't been maintained perfectly.
Even after 175k miles, a Saturn can still has plenty of life left, but it might have some issues and require some attention that isn't typically needed in the first 175k miles of the vehicle's life.
If it is still starting and running, but stalls sometimes, try to collect and share the details with us about what you are doing when it stalls, and what you are doing when it doesn't stall.
As you also mentioned, thr Service Engine Soon light indicates that there is a issue that has to do with emissions standards, and not necessarily an indication of any mechanical problems.
Old Nov 26, 2024 | 02:01 AM
I have over 240 k miles on my 95 SC2.
I racked up 265k miles on my '97 SC2.
There's plenty of life left in your vehicle. Every car goes through a phase where it seems like things are breaking one after another. But when you take a few steps back, you realize that most of them are simply parts wearing out because you're driving the vehicle longer than the expected lifetime of these parts. So it actually makes sense. But you got to pay to play. Still cheaper than a new car and the payments that come with it
Old Nov 26, 2024 | 12:25 PM
wow 265,000 miles its nothing major just parts and I have someone that works on them really cheap
Old Nov 26, 2024 | 12:26 PM
wow 265,000 miles its nothing major just parts although it has a problem of hesitating at times when I stop and then gas it we never figured out what that could be
whitelee28
Jun 14, 2020 07:38 PM
09VUEXR
Jul 25, 2017 10:19 PM
08astraxr
Saturn Astra
32
Apr 1, 2012 12:33 AM
wheezer
Aug 29, 2008 06:22 PM
lamont4689
Jul 2, 2007 12:34 AM
