leak just below the battery 96 sl1
Old Dec 20, 2009 | 08:16 AM
ktmac's Avatar
Default leak just below the battery 96 sl1
my daughter's 96 sl1 has a small/slow leak coming from the box just belowt he battery. i think it is transmission fluid? could someone tell me what this might be and how to fix it. it is very little fluid and the outside of the "box" below the battery is moist. the car starts up and runs find otherwise... Thanks.
The leak is definitely on the drivers side somewhere. it's not real bad, the car is running fine. the leak just started a couple of weeks ago when using the heat. it leaves very little circle stains in the driveway, but i really need to get it fixed. any help would be appreciated
problem solved transmission filter and gasket
Last edited by ktmac; Jan 29, 2010 at 09:18 AM. Reason: problem solved it was transmission filter and gasket
refinnejm
Jan 16, 2011 06:36 AM
doiga321
Sep 26, 2008 06:37 AM
Echo419
Dec 19, 2007 01:46 AM
green75
Aug 7, 2007 07:24 PM
blind527
Nov 22, 2006 09:33 PM
