keyless entry help
Old Sep 26, 2008 | 07:45 PM
shordinges's Avatar
well i just bought a 97 saturn sl2 on monday and lovin it. but i have had to work on a couple things, such as replace motor mount, axle seal, and a tune up. but the keyless entry doesnt work. i replaced the battery with the correct one. still doesnt work. manual says that press and hold the lock and unlock buttons for 7 seconds to sync it with the car but that doesnt seem the work. the guys at autozone said to check the fuse. but i cant find it and the autozone says that they dont have a way of finding it. i looked at the fuse box under the hood next to the battery and the one on the passenger side of the console in the car. none of them say something that may resemble a remote or keyless. any help would be appreciated
Old Sep 26, 2008 | 11:06 PM
There are two fuses on the instrument panel junction block that I would check first ... the ''BODY'' fuse (10A) and the ''LOCKS'' fuse (20A). They are both located near the ''CHIME'' fuse.
Old Sep 26, 2008 | 11:46 PM
shordinges's Avatar
alright i will check them out first thing in the morning. i remember seeing them but never checked them. just wondering, if it isnt the remote fuse then what else could it be? thanks for the reply
Old Sep 29, 2008 | 10:04 AM
I am assuming that the doorlocks operatemanually with the interior buttons, and that the doorlocks open and close when operating the vehicle on a daily basis which shows that the Remote Keyless Entry Module (RKE)is OK.
Are you sure you have the proper ''synchronization procedure'' for your car? You should be able to call the dealer to verify that.
Well, hopefully the remote keyfobwas not wiped out by the battery being wrong, but I guess that is a possibility. Might just have to replace the keyfob.
Old Sep 30, 2008 | 09:31 PM
shordinges's Avatar
sorry i havent been online for a while. internet was down. but the locks and windows in the car are all power. is there a way to test the system? and i did check both fuses and both were ok.Edited by: shordinges
Old Oct 1, 2008 | 07:50 AM
Please excuse my redundant questions, but could you answer these?
1. When you start the car and drive off, do the door locks close by themselves?
2. When you turn off the car, and remove the key, do the door locks open by themselves?
Old Oct 6, 2008 | 09:43 AM
Low Saturn's Avatar
Some will do that and some wont. Depends on how the system is programmed from the begining.
Old Oct 6, 2008 | 10:39 AM
Well, I have not worked on near the number of Saturns that Mike (LowSaturn) has, so I bow to his comments. But frankly, all the Saturns I have seen that came equipped with electric doorlocks and remote keyless entry will lock at ''drive-off'', and will unlock at ''shut-off''.
I was trying to establish if the locks only worked with the internal buttons, and at no other times. The thought being if the locks never operated except when manually triggered, then I would suspect the RKE module. However, if the doorlocks worked as I outlined, then I would suspect the keyfob itself was bad.
Old Sep 2, 2009 | 08:40 PM
Newbeak's Avatar
Default 96 sl2
I have recently had trouble with my remote entry as well.I thought it was the keyfob battery,but using a fresh one doesn't help.The problem is it sometimes locks/unlocks the door/pops the trunk,but often I press and press the button with no results.Is there some way to nail down an intermittent problem like mine? I have to get an oil change soon,and could ask my mechanic to look at it. I bought this car new,and love it.I have never had a major problem/repair.
Thanks
Old Sep 3, 2009 | 04:04 PM
Open the remote remove the battery and clean the contacts. If that fails pull onto your nearest SATURN service drive and they will reprogram the remote at no cost.
