Inside Driver door panel 1993 Saturn SL1
Old Jun 7, 2009 | 09:09 PM
rick1's Avatar
Question Inside Driver door panel 1993 Saturn SL1
How do i remove the driver door panel on a 1993 Saturn SL1?
I had it all off except by the door handle. I could not get it off. I had all the screws off and even the ones in the handle where you grab it to close the door. It looked like something on the handle where you pull to open and where the lock is, is holding it from comeing off but I could not find anything.
Thanks
Rick
Old Jun 7, 2009 | 09:46 PM
Did you push the retaining pins out ???
Old Jun 7, 2009 | 11:12 PM
clips on the rods which actuate the latch must be removed to separate the rods from the inner latch.
Old Jun 8, 2009 | 03:38 PM
rick1's Avatar
How do I locate and get at those??
Thanks
Old Jun 8, 2009 | 04:28 PM
you should be able to see them when you look down (between the door inner panel and metal of the door frame) at the latch area. Be gentle -- they are plastic
Old Jun 9, 2009 | 06:01 AM
rick1's Avatar
Thank you. The window wont roll up on Grandmas car and I am afraid the gears are stripped. it goes to a certain point and then the crank just spins and the window wont move. Im thinking I have to replace the window crank track.
Thanks again 4 all your help
dispatch8
Apr 27, 2015 01:09 AM
billsbigf8
Jul 25, 2010 12:03 AM
nikkihype
Jun 25, 2010 03:45 PM
chriSL2
Feb 25, 2009 09:27 AM
Drapesy
Audio/Visual Electronics
Jul 22, 2008 11:59 AM
