How do i replace the timing chain gasket on a 98SL1
Old Jan 27, 2010 | 04:41 PM
alex_0227's Avatar
Default How do i replace the timing chain gasket on a 98SL1
I just replaced the valve cover gasket and realized that the gasket on the timing chain cover needs to be redone aswell. How would I do that? Is there a good article out there about it?
Thanks
Alex
________
VOYEUR SPY
Old Jan 27, 2010 | 09:30 PM
hoseppi's Avatar
. It is silicone except for the crankshaft seal. You just have to take the cover off,clean both surfaces, and apply a bead of silicone on the cover. Are you sure it is leaking, because that's usually a fairly reliable seal. The crankshaft/vibration damper seal, however, does occasionally fail. It can be replaced without removing the timing chain cover.
jgroup
Jun 17, 2014 04:52 PM
Classof84
Jan 12, 2008 05:55 PM
95_SL2
Jan 6, 2008 09:51 PM
hartman
Apr 3, 2007 01:14 AM
hbtdawgs
Feb 8, 2006 05:39 PM
