High pressure on AC low pressure line
Old Apr 27, 2009 | 05:13 PM
FranconiaFriend's Avatar
Default High pressure on AC low pressure line
2000 SL2; getting no cold air from AC, but interior blower OK. Thought the compresser was OK so got a can to recharge. Upon hooking up to the low side (per instructions, with AC on full) the pressure indicates at 100 psi. Would a bad compressor give this indication?
TIA
Old Apr 27, 2009 | 07:42 PM
So are you in
Lower, Central/Middle, or Upper Franconia and how did a Saturn end up in that area?
Old Apr 27, 2009 | 09:37 PM
Either a bad compressor, or a massively overcharged system. Any idea at all as to the high side pressure?
Old Apr 27, 2009 | 09:41 PM
Originally Posted by sw2cam
So are you in
Not this Franconia
http://en.wikipedia.org/wiki/Franconia
But in the good ol' USA - near Alexandria VA
http://en.wikipedia.org/wiki/Franconia,_Virginia
Plenty of Saturns here!
Old Apr 27, 2009 | 09:45 PM
No, I could check at the auto part store for a tool to test ... but I suspect it is the compressor. If I recall correctly, it was serviced early last year and ran fine - so I don't know where an overcharging would have taken place (I did not have the bottle on it long enough to do it).
bewigton
Jun 11, 2011 12:02 PM
jlannigan
Jul 21, 2009 04:11 PM
jakeolson
Jun 5, 2009 06:08 PM
kuhnphil66
May 21, 2009 10:41 PM
Thomas123
Dec 10, 2008 03:43 PM
