Loud Vibration mostly when cold.
Old 04-11-2009, 03:13 PM
mjmurphy1955's Avatar
Default Loud Vibration mostly when cold.
I have a 1997 Saturn SL2 Sedan have had it a couple of years change the oil every 3,000 mi. recently it started vibrating I noticed it mostly as I started to drive off and after it was driven for about 25 min. the vibration
subsided. I thought it might be the drive train maybe the right halfshaft CV bearing? But now im not sure. I noticed whil i had the Manual Transmition Disengaged if I accellerated from 1k rpm to 2k rpm the vibration was very prevailing after the car warmed up it smoothed out quite a bit. I drove the car and noticed it would vibrate alittle on my way
down a hill and when i accellerated on the up hill it nearly went away.
then when i his a small bump i noticed small vibration and some squeeky noise. So I'm thinking it might be the CV bearing as part of the issue but the vibration sitting still while cold is somthing else?
I was thinking maybe Strut Torque Rods? or worse crank shaft?
Anyone have experiance with this issue?
Thank You
Mike
Old 04-11-2009, 07:43 PM
Sounds more like the passenger's side engine mounts have failed ... either that, or the tire on the right front has separated the belt from the casing. Rotate your tires first to see if the vibration/rough ride changes.
Old 04-25-2009, 06:57 PM
Default Loud Vibration In Saturn SL2
Hey Ocean Archer,
Just wanted to thank you.. nailed on the head it was the top passenger side
motor mount.
Thank you very much!
Old 04-25-2009, 07:06 PM
Glad to hear you are back on the road. Enjoy your ride ....
Ltmartinvenegas
11-02-2013 04:13 PM
zero467
03-08-2013 04:24 PM
clukas
12-13-2012 08:00 AM
shadetreemech
04-01-2011 10:50 PM
dapayne12
04-14-2009 10:25 PM
Quick Reply: Loud Vibration mostly when cold.
