High Idle
Old 02-02-2006, 11:47 PM
Raven's Avatar
I have a sw2 that has a high idle issue. Only happens sometimes. I have replaced the engine temp sensor, Still has the issue. Connector is good.Any ideas?
Raven
Old 02-05-2006, 07:57 AM
stevestar99's Avatar
Does the SES light come on? If so, go by Autozone for a free failure code reading.
Old 02-05-2006, 08:25 PM
Raven's Avatar
Light does not come on.
Old 02-06-2006, 09:33 AM
Need more info, it does it when it's hot, cold, only on Sundays. It could be an electrical or mechanical problem. You might want to pull the throttle body for an inspection. You could have a vacuum leak somewhere.
Old 02-06-2006, 01:55 PM
Raven's Avatar
Happens when hot, usually after accelerating hard. I cleaned the throttle body out on Friday and changed the PCV valve aqnd it hasn't done it since. Does this make sense? The PCV valve and port was really dirty...
Old 02-06-2006, 02:31 PM
Ya, all the crud build up on the TB could be holding the air restricter plate open. Also clean up the EGR. It should be routine maintenance when you change your plugs, clean TB, intake manifold, EGR and PVC. The oil fumes recovery hose on the valve coverallows all kinds ofoily sludgeto be sucked into the intake lines. Edited by: stevestar99
Old 03-12-2006, 02:06 AM
euroc's Avatar
The PCV didnt do it? Are their any cracks in the line? I changed mine out at the same time as my fuel filter. Between the two it fixed my idle problem.
Old 04-30-2008, 10:22 PM
saturnpower's Avatar
try the throttle position sensor it cost 15-20 dollars and took 30 mins it helped my 00 sl2
Old 05-01-2008, 11:41 AM
Low Saturn's Avatar
Two years man, two years. Most forums lock the ability to reply to an ancient thread after 30 days.
cloudsplitter8
08-24-2012 07:47 PM
Robkevin
03-11-2006 02:52 AM
pexmaster
03-11-2006 02:40 AM
bryant
02-27-2006 12:49 AM
henrylford
01-31-2006 01:12 AM
Quick Reply: High Idle
