Grommet Location for Valve Gaskret?
Old Dec 28, 2008 | 09:35 AM
jmayers's Avatar
I have a 97 Saturn SL. I replaced the valve gasket and was left with two grommets that were not used. Could someone please help me find where these grommets are located I think I found one but am not sure. Thank you in advance.
Old Dec 28, 2008 | 10:01 AM
Jmayers -
Did you use an OEM gasket set, or an after-market product?
Describe your left over parts more fully, please ...
Old Dec 28, 2008 | 12:28 PM
Low Saturn's Avatar
They go where the bolts go through the valve cover. Since you have a SOHC, you only have two. They usually get stuck to the cover, with the washer on top during removal.
Hopefully you got a preformed gasket and not those stupid kits that are the grommets and a tube of RTV.
Old Dec 28, 2008 | 01:22 PM
jmayers's Avatar
The only thing they had was the kit which is exactly what Low Saturn stated, a tube silicone and two grommets. I used the silicone but could not find where the grommets go.
Old Dec 28, 2008 | 06:33 PM
Low Saturn's Avatar
I''d remove all that RTV and install the correct gasket kit.
When you remove the bolts that hold down the cover, there will be two big washers and two grommets underneath.
celeste
Jul 11, 2010 04:46 PM
ds28
May 21, 2008 09:46 AM
iveyx001
Nov 8, 2007 07:03 PM
floridaboy32905
Apr 27, 2007 12:31 AM
mjeltema
Nov 3, 2006 09:33 PM
