gas pedal
Old Feb 18, 2009 | 09:35 PM
dtone90's Avatar
my gas pedal is sticking any suggestions how i could fix it
Old Feb 18, 2009 | 09:45 PM
Replace the throttle cable. Use OEM part here, as the after-market part will not hold up to the environment, and will corrode/freeze up
Old Feb 18, 2009 | 09:47 PM
Are you sure it the pedal? Are you sure it''''s the cable? Are you sure? ..... Ah hell don''t try to figure it out just go buy parts till you find the right one.Edited by: sw2cam
Old Feb 18, 2009 | 10:22 PM
Arrggghhhhh ... there I go jumping to conclusions again. My bad.
Of course, SW2cam is right, the sticking part may be the pedal, and not the cable itself ...
Old Feb 19, 2009 | 11:33 PM
ASKBCG's Avatar
My Pedal stuck a while back, but it was only in the idle position. It was easily resolved by cleaning the throttle body. I''d check that
Old Feb 22, 2009 | 04:30 PM
Originally Posted by ASKBCG
My Pedal stuck a while back, but it was only in the idle position. It was easily resolved by cleaning the throttle body. I''''d check that
Cleaning the throttle body ........ thats the first thing I''d do.
A can of fuel injector cleaner in a spray can does the trick.
Old Feb 24, 2009 | 07:08 AM
Did you clean the throttle body yet?
Rschriner17
Feb 7, 2014 09:50 PM
brendastgermain
Nov 27, 2013 03:33 PM
krazy Dan
Feb 2, 2013 08:07 AM
Jerm088
May 21, 2009 11:17 AM
nhughes18
Mar 6, 2008 10:45 PM
