my gas pedal is sticking any suggestions how i could fix it
Replace the throttle cable. Use OEM part here, as the after-market part will not hold up to the environment, and will corrode/freeze up
Are you sure it the pedal? Are you sure it''''s the cable? Are you sure? ..... Ah hell don''t try to figure it out just go buy parts till you find the right one.Edited by: sw2cam
Arrggghhhhh ... there I go jumping to conclusions again. My bad. Of course, SW2cam is right, the sticking part may be the pedal, and not the cable itself ... |
My Pedal stuck a while back, but it was only in the idle position. It was easily resolved by cleaning the throttle body. I''d check that
Originally Posted by ASKBCG
My Pedal stuck a while back, but it was only in the idle position. It was easily resolved by cleaning the throttle body. I''''d check that
Cleaning the throttle body ........ thats the first thing I''d do. A can of fuel injector cleaner in a spray can does the trick. |
Did you clean the throttle body yet?
