Gas mileage for SL1
Old Dec 22, 2012 | 01:34 AM
lconley669's Avatar
Default Gas mileage for SL1
I have 2001 SL1 and I have been noticing lately since July of this year that my fuel mileage has been going down. I use to be able to get 100-110 mile to a 1/4 tank. Now I am lucky to get 50-70 miles to a 1/4 tank. I have replace the following parts:
Spark plugs
Fuel Filter
Spark Plug wires
The other think that I have noticed is that every once in a while the car will die shortly after I start it. It seems like the engine is being choked and i have to press on the gas to get it to start. I am working on checking the fuel pressure to see if that is the issue.
If there is anyone out there that knows what i could be, please let me know.
Old Dec 22, 2012 | 07:26 AM
replace ects (coolant temp sensor) AND connector.
Source parts from GM dealer
Old Dec 22, 2012 | 09:20 AM
Try some Techron fuel injector cleaner in a tank of gas too. Have you ever cleaned the throttle body?
Old Dec 22, 2012 | 03:06 PM
keith's Avatar
Check your warm idle speed, if it is over 950 rpm, then you may have an issue with the intake manifold gasket around the #1 cylinder.
Old Dec 23, 2012 | 10:21 AM
cspotkill's Avatar
mine was doing the same thing and i replaced the ect and it fixed it for me got it autozone for pretty cheap to.Derf has good advice take head to it.
drivewayguy
Jan 6, 2014 11:04 AM
jwngr
Dec 23, 2013 10:20 AM
armedgentleman
Jun 12, 2008 09:44 AM
HeatherP00
Oct 10, 2005 12:51 AM
HeatherP00
Oct 10, 2005 12:21 AM
