fuel pump replacement
thanks. also would that prevent the car from starting or how can i make sure its the problem
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
where would the test port be located? and i dont think i do hear it prime should i be listening from the rear or under the hood for that
< =text/>
urchinTracker();
The test port would be just before the fuel rail. You should be able to hear the pump prime from inside the car. As soon as you turn the key to the run position (without starting the car), you should hear hum for a few seconds.
