Flashing Service Engine Soon
Old Jan 9, 2007 | 02:58 AM
kellymo's Avatar
Granted my car 96 sl1wasn't running completely perfect but it was better my light was on but not flashing and the car wasn't vibrating, and jumping so bad, & taking forever to build up speed then all the sudden taking off. I broke thevacume hose that attaches to the vacume harness along with another hose to the top of the motor. I took it to the garage they removed thestuck broken piece out reconnected the hose and sealed it with proxy. I assumed once thevacume hosewas fixed the car would return to normal but that is not the case. I changed the spark plugs & wires, both coil packs, cleaned the egr valve replaced coolant temp sensor & i don't know whatelse to do. If anyone has any suggestions my husband isn't too auto inclinedso most of this is done by me .
Old Jan 9, 2007 | 09:39 AM
Get codes read at Autozone or similar.
Post them here and we'll help you sort it out....
Derf
Old Jan 10, 2007 | 05:20 PM
hutch109's Avatar
If you have a FLASHING CEL you better STOP driving it - it is usually indicative of a MAJOR misfire. If you continue to drive - you will cause damage to your CAT and possibly other items. You said you did wires, better CHECK and RECHECK the firing order, even if you did them one at at time... Make sure they are in the right order.
Eric
Old Jan 10, 2007 | 05:29 PM
kellymo's Avatar
my light wasn't flashing till the vacume hose broke, once that happened they said the motor wasn't getting the correct mixture of fumes, so instead of ordering the harness and new hose they removed the broke piece and plugged the hose back in and sealed it with proxy. i think the whole part needs to be replaced and not tried to be sealed back together cause the lights still flashing, car vibrates like no tomorrow. I'm going to have the codes read tonight so i will post them when done
Fire_N_Ice
Jan 19, 2023 07:25 AM
motmmp247
Feb 7, 2008 08:54 AM
dec29p
Jun 18, 2006 06:37 PM
tommy7133
Feb 25, 2006 12:35 AM
tommy7133
Aug 16, 2005 02:02 PM
