Engin temp
Old May 11, 2013 | 02:50 AM
Garry 28's Avatar
Default Engin temp
The temp on my 96 sl2 runs much hotter than befor I changed my ects witch I did because the old one was the original plastic one and the idel was stating to become affected the car always ran at the 1/4 mark changing the senser fixed the idel problem but know the car runs hotter why?
pleas help
Old May 11, 2013 | 08:54 AM
Where did you get the sensor? If it's not from a GM dealership, then that's most likely the reason. Aftermarket sensors don't seem to work well on the Saturns.
Old May 11, 2013 | 06:01 PM
Garry 28's Avatar
Default Runs hotter
U are right I got the sensor from auto zone how is it different from the dealer. I did call A dealer to see if there's was different or like the original but they were unable to say. I also have read on this site that the various models run at different temps but as this is the only deviation from the 1/4 mark it seems unlikely that it should run hotter now right? How can the sensor make it run hotter it reads the temp it dose not regulate it. Have u herd of this happening before?
Thank u for Ur help
Old May 11, 2013 | 10:13 PM
Not really sure, but the value of an after-market sensor may have a different resistance curve. It won't cause your car to run hotter, but the gauge may report a bogus level
Old May 11, 2013 | 11:17 PM
+1 likely different resistance/temp curve
the car is not running hotter.
Old May 13, 2013 | 03:25 PM
Garry 28's Avatar
Default Temp
Thanks guys I order one from gm deler will let u know how it goes
Old May 16, 2013 | 07:09 PM
Garry 28's Avatar
Well I got the ects from the gm dealer and it dose nothing different if the sensor is thinking the car is hotter then it is how come it dose not kick on engine fan
Why dose simply changing this sensor Chang the engine temp what should i do ?
Old May 16, 2013 | 07:21 PM
The word is. "does"
The temp does not change. The proper etcs or the one from GM is calibrated correctly so the reading on the temp gauge shows as GM intended.
Again the cooling fan should not turn on till you get to about the 3/4 mark A/C off. Fan should be on at ALL times with A/C on. Thats if the damn fan is working in the first place, and you have no idea if it works or not.
Old May 17, 2013 | 07:38 AM
Run a couple of jumper wires from the battery to the fan and make sure it works. If not, then you probably need to replace it. If it does, perhaps the fan relay is not working.
rabobanks
Jul 7, 2008 09:10 AM
gs69350
Jun 28, 2007 08:04 PM
projectpete19
May 5, 2007 12:18 AM
thatsreality
Apr 9, 2007 03:43 AM
buzzin_bob
Sep 13, 2005 01:30 PM
