Dang P0341 code
Old Jul 22, 2025 | 04:50 PM
OldDawg's Avatar
Default Dang P0341 code
Hi all. 2002 SL2 with 108k and auto.
It started running rough at low idle and sometimes wouldn't start and sometimes stalled.However, it would start with a jump, but had to keep foot on the gas to keep it running. I researched and watched a bunch of videos where the problem could be a multitude of things.
I removed the wires, plugs, coil packs, ignition module, and disconnected the battery (first). I cleaned, wire brushed, and sprayed electronic cleaner where needed. Reassembled and nothing changed.
Im now leaning toward the battery. Im picking up a new one tomorrow and let you know. In the meantime, any suggestions? It has spark to all 4 plugs, fuel is fine. Thanks! Oh, and battery voltage is charging at around 14v, while resting it's about 12.4v.
Old Jul 22, 2025 | 09:00 PM
grcauto8453's Avatar
I'm a fan of testing things. Load test that battery would be the first thing. Might be the last.
Russ31
Jun 10, 2025 02:21 PM
pic_az
May 30, 2025 08:12 PM
Afskwarek
Jan 11, 2025 10:50 AM
CarterC
Mar 27, 2024 02:41 PM
pitar
Jan 3, 2006 12:39 AM
