Crazy issues with '94 SL2 525k+ miles
Old Mar 14, 2022 | 05:27 AM
R.johnston's Avatar
Default Crazy issues with '94 SL2 525k+ miles
Okay, so I was dealing with an idle issue last week, and I changed the throttle position sensor. Also, I did a complete tune-up including plugs wires air filter PCV valve oil and filter. My idol is still crazy. Any ideas out there what this could possibly be please let me know. You can send me emails to raymondjohnston22@gmail.com. Annie and all ideas and or guidance is greatly appreciated. I've had the car since it was new as you can tell by the title it has 525,000 plus miles on the original transmission and engine. Don't want to let this car go great little car please help
Also I can be contacted at 803-846-0562. Please feel free to call and or email. Thanks for all y'all's continued help and guidance
Old Mar 14, 2022 | 07:45 AM
See Rube's post below. Then see mine.
Old Mar 14, 2022 | 09:12 AM
Have you ever replaced the ECTS? If not, it might be time to find an OEM one along with the pigtail. Just a suggestion.
Old Mar 15, 2022 | 06:25 AM
If your idle is slightly high and stable, Rube probably has the answer.
I interpreted as you meant and had crazy high idle. Hence the things I listed.
There is also the PCV valve to intake manifold hose, which, when it tears or comes off, creates a massive vacuum leak as it pulls in un metered air.
I'm thinking you forgot to put it back on when you changed the PCV valve.
Old Mar 15, 2022 | 06:29 AM
How many rebuilds on that original engine?
Or how many miles per quart?
Old Mar 15, 2022 | 08:36 AM
I'm not sure we're going to hear back from him, derf. I was wondering the same thing as you, though.
Old Mar 19, 2022 | 09:36 AM
R.johnston's Avatar
There have been no rebuilds to the original engine. The original engine is just that the original Union I have done no rebuilds all I've done is maintain the engine and not drive crazy. It's not a high idle it's a fluctuating idle.
Old Mar 19, 2022 | 09:44 PM
Fluctuating idle at what RPM once at operating temperature?
Old Mar 20, 2022 | 08:10 AM
When's the last time you cleaned the throttle body? It could be as simple as that or maybe even a gasket. If you haven't ever replaced the ECTS and pigtail, though, I'd suggest doing that.
x86guru
Apr 30, 2010 04:36 PM
imaukfan
Jun 10, 2008 06:34 AM
patboone7
May 7, 2008 10:18 AM
sl1driver
Jan 20, 2008 08:56 PM
sl1driver
Jan 9, 2008 09:16 PM
