code po341
Old Jan 24, 2008 | 08:37 AM
rsirvello's Avatar
low saturn the coolant sensor fixed the starting problem but iam still getting po341 code any input on this thanks
Edited by: sw2cam
Old Jan 24, 2008 | 09:11 AM
Low Saturn's Avatar
The PCM is still detecting a misfire. Check for corrosion at the coil pack terminals, spark plugs, wires or oil in the spark plug wells.
Old Jan 24, 2008 | 04:22 PM
rsirvello's Avatar
what would oil plug wells bei ahve all ready replaced plugs wires and did not see corrrison on coil pack where plug wires go
Edited by: sw2cam
Old Jan 24, 2008 | 09:17 PM
You'll not be looking in an oil well....you need to look in the spark plug well. Pull each wire checking for oil or white powder. Then check the inside of the wires and the coil pack posts for whit powder.
Oil wells are a place that oil is pumped out of the ground.Edited by: sw2cam
james clark
Feb 23, 2011 09:24 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
