low saturn the coolant sensor fixed the starting problem but iam still getting po341 code any input on this thanks Edited by: sw2cam |
The PCM is still detecting a misfire. Check for corrosion at the coil pack terminals, spark plugs, wires or oil in the spark plug wells.
what would oil plug wells bei ahve all ready replaced plugs wires and did not see corrrison on coil pack where plug wires go Edited by: sw2cam |
You'll not be looking in an oil well....you need to look in the spark plug well. Pull each wire checking for oil or white powder. Then check the inside of the wires and the coil pack posts for whit powder.
Oil wells are a place that oil is pumped out of the ground.Edited by: sw2cam |
