Clogged Fuel Return Line
Old Jul 30, 2015 | 07:20 PM
dwd375's Avatar
Default Clogged Fuel Return Line
I have a 1994 SL1 SOHC TBI Saturn. I recently replaced a mostly severed hose that was only a few millimeters intact for the fuel return line. So all it was doing was holding the hose. Its been like that for years I found out. So much fuel would pour out when the engine wad cold.
My first question is this: How would I know if the fuel return line is blocked in any way?
My second question: Was my Saturn originally built with a 3/8" metal fuel return line from the engine, then was connected to a 1/4" outer diameter hose that went to the fuel tank? I find it odd that it would be a thick line to a thin one.
Old Jul 30, 2015 | 09:54 PM
If you have a blocked return line your fuel pressure would be much higher than desired.
Old Jul 30, 2015 | 10:02 PM
dwd375's Avatar
Does anybody know if my TBI engine has a fuel pressure test connection, or off I have to install one myself?
crimsonandblue
Jun 12, 2013 11:47 AM
sl2noob
Feb 23, 2011 05:39 PM
edmanrck
Jul 19, 2010 07:12 PM
raedar
Aug 11, 2009 09:09 PM
gbelous
Jun 1, 2007 03:38 PM
