Car uses oil and blows smoke when idiling??
Old Jun 15, 2009 | 07:53 PM
iamaukfan's Avatar
Default Car uses oil and blows smoke when idiling??
I have posted here with problems before but couldn't remember my password so had to start a new account. I have a 99 Saturn SL2, 117,500 miles, automatic. When I leave the car idiling for any length of time, it smokes something terrible, and for a few minutes while I drive down the road. My car uses a lot of oil. It uses between 2 to 3 quarts between changes, and if I happen to let it go over even a few hundred miles it goes really fast. What is this and can it be fixed?? Thanks!!
Old Jun 15, 2009 | 08:12 PM
Hmmmm -- My crystal ball predicts a major engine rebuild/overhaul in your future ...
Old Jun 15, 2009 | 08:33 PM
Likely due to the oil control rings seized in place on the pistons are not sweeping the oil back down the piston walls -- it's bypassing them and burning in the cylinders.
Can be fixed by rebuilding the bottom end.
Should also check the head while its off -- valve seats and valve guide seals often require attention as well...
Old Jun 15, 2009 | 09:37 PM
budsjlm's Avatar
brother who woked for saturn said its a verry comon problem try throwing som cleaner throught it i do it ever other oil change to keep things clean
Old Jun 16, 2009 | 05:42 AM
Blowin smoke at idle = likely past the "cleaner helping stage" of life
Old Jun 16, 2009 | 10:00 AM
budsjlm's Avatar
ill give ya that one
Old Sep 4, 2009 | 11:19 PM
SaturnSl1?Sl2?'s Avatar
What kind of cleaner do you use cause im starting to get smoke when i hit the gas
Old Sep 13, 2009 | 04:55 PM
JMuse84's Avatar
Cleaner is not likely to help you either. Sounds like you have head issues. In particular valve stem seals.
rdhiri
Apr 21, 2014 10:05 PM
dbhost
Sep 23, 2012 08:55 AM
cadman33619
Jun 16, 2009 05:46 AM
crzybone
May 5, 2008 09:11 AM
blue99sc2
Nov 1, 2007 06:15 PM
