Car shakes in any gear
Old May 7, 2009 | 10:21 PM
02satyslvr's Avatar
Default Car shakes in any gear
hello everyone. I own a 02 SL2 it has 99482 miles on it 5-sp manual. Recently the car started to shake back and forth no matter what gear im in only when the car warms up. Thinking it was the clutch i replaced it. It wasn't the clutch...any ideas from anyone????? Thank you
Old May 7, 2009 | 10:23 PM
Upper torque axis (engine) mount ever changed?
(Clutch was an expensive guess)
Old May 8, 2009 | 09:25 AM
02satyslvr's Avatar
never changed any mount. Does a mount make sense if it only does it when it the engine warms up??
Old May 8, 2009 | 04:50 PM
Well, not really, but rubber has a tendancy to be a tad 'softer' when warm ... I'd check both mounts on the passenger side of the car .....
Old May 8, 2009 | 05:22 PM
02satyslvr's Avatar
all mounts are fine...can't figure it out it only does it when im driving i've tried taking it out of gear while going down the road putting it in neutral nothing does not shake only while cruzing at a steady speed in any gear...idles fine
Old May 8, 2009 | 07:58 PM
Here's a test to try -- take it out of gear while going down the road, then gently press the gas pedal to make the engine approximate the RPMs at that speed to see if your shaking occurs ....
Old May 11, 2009 | 09:36 PM
02satyslvr's Avatar
it was the EGR valve
redvue
Apr 15, 2011 10:35 AM
blusaturn1
Mar 18, 2009 11:58 PM
blusaturn1
Feb 18, 2009 04:36 PM
projectpete19
Dec 12, 2006 09:06 PM
projectpete19
Dec 7, 2006 01:14 AM
