Car makes rattle noise after I drive it
Old Apr 8, 2008 | 08:54 PM
latestgood's Avatar
Hello,
My car makes a rattle noise from the passenger transmission I think. This only happens after I drive it at least 2 hours. When the noise does appear, it gets worse and I push the gas.
could this be caused by a radiator?
Thanks!
Old May 3, 2008 | 08:19 PM
CharlesWashburn's Avatar
I have a 94 saturn sc2 and i had the same rattling noise. All of the forums
told me that it was the timing chain and to replace all of the parts along with
it. After purchasing and replacing the timing chain the noise continued. I
took it to a Saturn dealer and they said that it was the belt tensioner and i
recently replaced it and the noise stopped, i also found that the heat shield
was also making a noise. You should located your belt tensioner and listen
closely to it. Good Luck.
Old May 5, 2008 | 09:20 AM
Low Saturn's Avatar
Originally Posted by latestgood
Hello,
The transmission is on the drivers side.
Safely lift the car in the air and determine where the noise is coming from, from under the car.
My catalytic converter was making a bunch of noise. The way the noise was reflecting off the ground made it sound like it was coming from the passenger side of the engine when the hood was open.
BigE-78
Jun 29, 2011 05:50 PM
sl2owner
Jan 25, 2011 01:28 PM
exern
Feb 26, 2010 03:02 PM
jllacourse
Aug 21, 2009 03:54 PM
rabobanks
Oct 11, 2007 10:31 AM
