Can't diagnose
Old Mar 26, 2011 | 02:03 PM
nwells's Avatar
Default Can't diagnose
Hi All,
I'm new here, so go easy on me. I have a '95 SL1 - Manual. I am having a starting issue that I can't seem to figure out. Here is what I've done and tested so far:
1.) Will only start at WOT
2.) Fuel pressure tested fine
3.) Spark plugs are good
4.) Received EGR system fault code; Replaced EGR valve - didn't help
5.) Replaced MAP sensor - didn't help
6.) Injectors are fine
7.) Cleaned throttle body - didn't help
8.) Compression check showed a little low on cylinder 1, but the others were fine.
Once I get the car started it acutally runs great. It's just getting it started that's a P.I.T.A.
Any help with how to proceed would be greatly appreciated.
Thanks guy!
Nathan
Old Mar 26, 2011 | 02:26 PM
Replace ETCS and connector that sends info to the computer, buy from dealer not NapaCheckerAdvanceZone
Old Mar 26, 2011 | 03:55 PM
nwells's Avatar
Is there a name for the connector that sends the info to the computer?
Thx for the help.
Old Mar 26, 2011 | 10:37 PM
YES, it's called the ETCS and connector.
Old Mar 31, 2011 | 11:12 PM
nwells's Avatar
Thanks for the help. The ECTS wasn't the problem. I finally figured out the issue. I took the intake manifold off and took it to NAPA to have them clean it in their heat tank. The cleaning seemed to do the trick.
uncljohn
Mar 19, 2010 09:44 AM
mikes 1994 z28
Engine & Internal
Apr 7, 2007 11:50 PM
MCapone
Mar 16, 2007 11:58 PM
mikes 1994 z28
Jun 12, 2006 04:19 PM
Mudshack
Oct 28, 2005 06:01 PM
