Can't diagnose
Hi All,
I'm new here, so go easy on me. I have a '95 SL1 - Manual. I am having a starting issue that I can't seem to figure out. Here is what I've done and tested so far: 1.) Will only start at WOT 2.) Fuel pressure tested fine 3.) Spark plugs are good 4.) Received EGR system fault code; Replaced EGR valve - didn't help 5.) Replaced MAP sensor - didn't help 6.) Injectors are fine 7.) Cleaned throttle body - didn't help 8.) Compression check showed a little low on cylinder 1, but the others were fine. Once I get the car started it acutally runs great. It's just getting it started that's a P.I.T.A. Any help with how to proceed would be greatly appreciated. Thanks guy! Nathan |
Replace ETCS and connector that sends info to the computer, buy from dealer not NapaCheckerAdvanceZone
Originally Posted by sw2cam
(Post 24514)
Thx for the help. |
YES, it's called the ETCS and connector.
Thanks for the help. The ECTS wasn't the problem. I finally figured out the issue. I took the intake manifold off and took it to NAPA to have them clean it in their heat tank. The cleaning seemed to do the trick.
