A/C problems help!!
Old Apr 19, 2011 | 02:40 PM
mattman's Avatar
Post A/C problems help!!
I have a 2001 Saturn SL2. Okay i took it to a mechanic last summer told me my compressor was bad. It had always had a slow leakWell, couple weeks ago i replaced the the compressor and the receiver/drier. Took it to the shop to get it vacuumed and charged, they vacuumed the system but told me there was that small leak out of the hi and low side valves so they didn't replace the freon and didn't charge me. Went and put the freon in myself took the put it 1.5 lbs of freon (24oz) and didn't get cold. The freon bottle didn't even get cold but the system took it. at 30mph no change. at 70 mph it would get a bit colder. and now 2 weeks later no cold no matter what. Any suggestions?? i'v been messing with this for over a year!
Old Apr 19, 2011 | 03:22 PM
A leak in both the high and the low side valves ? Are you referring to the test connection valves where one hooks the gages to checkout the system, or do you mean the valves within the compressor itself ??
Old Apr 20, 2011 | 10:21 AM
mattman's Avatar
Yes high and low. And yeah where you connect guagues and put freon in is where they told me it was leaking. They showed me but I couldn't hear or see any freon coming out but they just used the leak tested that beeps when it's get near freon I assume.
Old Apr 20, 2011 | 10:00 PM
why are you expecting a refrigerant system with known leaks to behave like one that has no leaks?
If the schrader valves are leaking, get them re-cored/replaced. Not sure why the shop didn't offer to do that -- it takes only a few minutes.
Old Apr 21, 2011 | 12:18 AM
Default RE: A/C Problems
Originally Posted by mattman
I have a 2001 Saturn SL2. Okay i took it to a mechanic last summer told me my compressor was bad. It had always had a slow leak Well, couple weeks ago i replaced the the compressor and the receiver/drier. Took it to the shop to get it vacuumed and charged, they vacuumed the system but told me there was that small leak out of the hi and low side valves so they didn't replace the freon and didn't charge me. Went and put the freon in myself took the put it 1.5 lbs of freon (24oz) and didn't get cold. The freon bottle didn't even get cold but the system took it. at 30mph no change. at 70 mph it would get a bit colder. and now 2 weeks later no cold no matter what. Any suggestions?? i'v been messing with this for over a year!
From what you say above, the shop vacuumed the system but didn't charge it because of the leaks. That means that when you added your Freon, there was air in the lines again. Also, after two weeks - everything has leaked out again. Replace the lines that have the gage fittings and have them vacuum the system and test it again....
turbobuick
Jun 27, 2008 10:45 PM
Shadowman750
Mar 28, 2008 10:50 AM
ardasl2
Jan 12, 2008 05:58 PM
CoastGuardGuy
Jun 27, 2006 01:25 AM
betinaq
Jul 14, 2005 01:23 AM
