A/C Not Working
Old May 14, 2007 | 05:30 PM
ltufd1802's Avatar
My 92 SL2 has A?C and the switch appears to be on but it does not seem like the compessor is activating and the air is not getting cold. I was wonder what the problemmay be? Thanks
Old May 14, 2007 | 11:13 PM
ducky's Avatar
1-As old as your car is the most likely problem is that freon has escaped from a leak and the source of the leak be found and repairs made including replacement of the filter/drier before even contemplating recharging with refrigerant. Most DIY'ers jump to the store bought recharge cannisters (no R12 available for your model year) in a poor attempt at simple refilling without finding the source of the leak that inevitably leaks out the new replacement refrigerant over a period of time, some leak out immediately while others leak anywhere from a few days to a season.
2-You must realize that your a/c system used R12 Freon and that refrigerant has fallen out of favor insofar as repairing/recharging because R12 is now expensive (no longer manufactured) and difficult to find. Underground markets exists as well as clone brands if you're interested in cooling for just a season or two. There are issues involved requiring consideration ofcosts between retaining R12 as the original cooling refrgerant or converting to the accepted R134a refrigerant.
3-Your old system should be evaluated by a pro with due consideration to how long you want to hold onto your car for assessing the amount of money you want to invest to repair your a/c.
Old May 15, 2007 | 01:58 AM
ltufd1802's Avatar
I checked the wire going to the compressor with a test lightand there is no power going to the compressor when the button is turned on inside the car. Does anyone know what may cause this to happen.
Xanderj13
Jul 19, 2007 09:59 AM
SurferDudeUSA
Jun 30, 2007 12:45 AM
neiby
Apr 12, 2007 07:33 PM
mfunk49
Jan 27, 2007 10:13 AM
sdntive
Jul 28, 2006 06:38 PM
