bucking in idle while at stoplight
Old Mar 27, 2011 | 09:11 AM
flores77's Avatar
Default bucking in idle while at stoplight
hi guys i need some help on this one. i have a 98 sl2 thats want to buck when im sitting at a stop light, and from time to time it will stall out while sitting at light also . it only does it when i have it gear. if i shift it to nuetral it runs smooth as can be, but as soon as i put back in drive it starts bucking. now i cleaned the egr valve, replaced tps senor, iac valve , and cleaned the map sensor port hole on intake. also the ect sensor is about 1 and a half yrs old from autozone. i also cleaned the ignition coil towers, but not the igniton module. also i havent done the can trick to see if egr valve is bad. also i have to prime the fuel pump each time to start car if that has anything to do with my problem. i know these care have known issues ith the fuel pumps. any other suggestion would be greatly appreciated. as of right now im stumped.
gnknt
Jun 21, 2009 07:16 PM
VueRedline04
Jun 20, 2008 07:03 PM
jcm22
Jul 9, 2007 11:26 AM
z4me95
Aug 27, 2006 01:57 PM
rottie2
Apr 13, 2006 03:31 AM
