-   -   automatic seat belts (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/automatic-seat-belts-2796/)
jfm567 Jan 9, 2009 07:54 PM
Originally Posted by Low Saturn
It happens. Whenever I pick up a 91-94 with the autmoatic belts, I just do a swap over to the 1995+ fixed style.
is there any way you can walk me through the replacement? The junkyard said they have it, I just don''''''''t know where to start when i look at it! [img]smileys/smiley5.gif[/img]
Replacing the module or swapping in 95+ style seatbelts?
the module.
Low Saturn Jan 10, 2009 10:30 AM
Remove the four screws holding the center console down. Lift it from the rear a few inches, unplug the three electrical connectors attached to the module then remove the module. Its snaps in place.
jfm567 Jan 21, 2009 12:39 PM
I found the two screws in the front, but im having trouble finding the other two.......
Low Saturn Jan 21, 2009 12:57 PM
Do you have an armrest? Or nothing to rest your elbow on?
jfm567 Jan 21, 2009 01:00 PM
nothing. just the shifter, E-brake, and a tray.
Low Saturn Jan 21, 2009 01:09 PM
At the back of the console (behind the e-brake handle)there is a small square piece of carpeted cardboard in the recess. Maybe 3"x3" square. Remove it and there will be two phillips screws under it.
jfm567 Jan 21, 2009 01:41 PM
aha! your amazing, i wouldve been searching for days. so i got to the part, and i detached it, but the connecters are on there with freakin'' super glue. i pushed down on the tab and pulled but it didnt budge at all.
jfm567 Jan 21, 2009 02:40 PM
1 Attachment(s)
Ok, i finally got the connectors off and took the part out. it was so stuck on there because the connectors are HORRIBLY corroded. do you think its the corrosion that made the part not to work? the passenger side worked which leads me to believe it was all the corrosion on the "blue" connector on the module. I have a picture of the corroded connection, but its bad image quality....
the one on the right is terribly corroded-
Attachment 2013
Low Saturn Jan 21, 2009 02:48 PM
Ohhhhh yeah.
jfm567 Jan 21, 2009 02:54 PM
Ohhhhh yeah.
alright, im gonna scrape these off and rub them down with alcohol. Then ill put it in the car and tell you the news. corrosion destroyed my old camera so i know it does have some bad effects....
