Ambiguous cylinder head bolt torquing instructions
Old Nov 2, 2025 | 01:58 PM
fryode's Avatar
Default Ambiguous cylinder head bolt torquing instructions
I'm confused because the online manual says one thing while tutorials I've seen say another. This is on a 2002 SL2 DOHC LL0 engine, for the record.
In video tutorials, I see 37 ft lbs + 90 degrees as final torque spec. Documents and other online references say finger tight, 22 ft lbs, 33 ft lbs + 90 degrees.
But the online manual has that last line there that says another 90 degrees is the final step for a total of 180 degrees beyond 33 ft lbs. I searched far and wide and couldn't see any reference to this. If I used the wrong search terms and it's been covered elsewhere on the forum, I apologize. It would be nice to get a definitive answer whether the process really is: Finger tight, 22 ft lb, 33 ft lb, +90 deg, +90 deg.
Thanks in advance.
Old Nov 2, 2025 | 03:11 PM
grcauto8453's Avatar
Home >> Saturn >> 2002 >> SL2 L4-1.9L DOHC VIN 7 >> Repair and Diagnosis >> Specifications >> Mechanical Specifications >> Engine >> Cylinder Head Assembly >> System Specifications >> Cylinder Head Torque & Sequence
CYLINDER HEAD BOLTS
- First Pass 30 Nm (22 lb. ft.)
- Second Pass 45 Nm + 90° (33 lb. ft. + 90°)
Old Nov 2, 2025 | 03:14 PM
I would follow the online manual instructions. These are reprints of factory manual pages. Use new head bolts and lubricate the threads lightly with engine oil.
Old Nov 3, 2025 | 11:28 PM
Greg97SW2's Avatar
I see what you mean about ambigious since it states to do the first +90 degree before it mentions installing the degree tool. I'm pretty sure the procedure I've used only involved only a single 90 degree turn during torquing as the final sequence.
Stove
May 8, 2025 08:51 AM
Gunnar
Sep 18, 2024 09:53 AM
tweakweak
Aug 11, 2024 11:52 AM
dallam1
Engine & Internal
Apr 20, 2023 07:27 AM
amilehigher
Nov 20, 2021 08:24 PM
