99 SL2 keeps cutting off
Old Nov 21, 2008 | 03:00 PM
Cj1984's Avatar
I have a 99 SL2 that will start up, but it only stays on for a sec. The battery and air bag light keep coming on. I replaced the battery but its still doing the same thing. Im guessing its the alternator but I dont wanna start working on it and thats not the problem either. Does anyone know what the problem is?
Old Nov 21, 2008 | 03:36 PM
The problem is ... you need to test things before you replace them.Edited by: sw2cam
Old Nov 22, 2008 | 10:16 AM
Cj1984's Avatar
Can''t do that because the car wont stay started so I cant take it to get tested.
Old Nov 22, 2008 | 10:27 AM
Did you test the battery when you went to the store to buy a new one?
The car should have run just fine with a fully charged battery untill it went dead, so if you put in a new battery and the car started and died right away ... It''s not the alternator.Edited by: sw2cam
Old Nov 22, 2008 | 10:58 AM
Check the IGN 3 fuses both underneath the hood, and on the instrument panel junction block (I/P JB)inside the car. Also check the IGN 4 fuse under the hood, and the IGN 1 fuse on the I/P JB inside the car.
If all those fuses are good, the possibility of a defective ignition switch arises, but would need toconduct additional tests before making the decision to replace the switch ...
Quadcouper
Feb 2, 2014 04:13 PM
2000SaturnLs2
14
Mar 23, 2013 08:11 AM
screamin77
Jul 20, 2009 08:26 PM
green75
Aug 7, 2007 07:24 PM
90lxstang
Apr 5, 2007 03:05 PM
