99 SL - Blinker/Flasher relay clicking away like crazy!
Old Aug 5, 2011 | 05:30 PM
JustinsSaturnSL's Avatar
Default 99 SL - Blinker/Flasher relay clicking away like crazy!
I have a 99 SL Sedan. I will just be driving along or sitting there (with car running) when all of a sudden the relay that controls the blinkers and also the flashers, the "Combo relay" just above the chime box will click anywhere from a few times, to going completely wild clicking away for a few seconds or a minute, then stop. I have not noticed any other ill effects but I cannot believe that something is not about to go horribly wrong. I have replaced it, this has not helped. Does anyone know whats wrong?
Old Aug 6, 2011 | 04:47 AM
There might be a possible problem going on with the turn signal swith located inside the steering column.
My Saturn is not driven a whole lot and is a 94 so age and usage may cause some corrosion to take place in the switch contacts.
I have found that to happen on my car periodically. I have also found that driving it more often and actuating the turn signals cause the switch contacts to apparently clean themsleves.
Is this a positive cure? No, I am guessing, it could be coincidence. Dunno. I have fooled myself before.
Although as long as it continues to sort of fix things I am not going to figure out how to pull the steering wheel and look at what is going on.
Old Aug 9, 2011 | 10:34 AM
OK one thing I have noticed is that if I turn on the blinker the clicking stops immediately. Should I replace the blinker switch? IT does not seem loose or anything odd, but i cant see what else it could be? Wires somewhere that deteriorated?
Drew
Oct 24, 2012 09:48 PM
RjION
News, Updates & Announcements
Jan 6, 2012 12:08 AM
JB721
Feb 20, 2011 05:25 PM
busboyblues
Feb 6, 2007 12:01 AM
elkslayer69
Sep 29, 2005 06:25 AM
