98 SL1 rear turning signal
Old Apr 2, 2009 | 09:17 PM
alex_0227's Avatar
Default 98 SL1 rear turning signal
I had to take off my rear taillight today, and after i put them back on and drove for a while, my rear right turning signal stopped working. Also, the front right signal works twice as fast. Any ideas where I should look?
Thanks alot.
________
PUBLIC STADIUM
Old Apr 2, 2009 | 10:57 PM
replace the bulb on the side you had removed
Old Apr 3, 2009 | 07:19 AM
Sounds like an excellent suggestion from where I sit ...
Old Apr 3, 2009 | 11:12 AM
alex_0227's Avatar
the bulb and the fuse are both good
________
Marijuana Vaporizer
Old Apr 3, 2009 | 12:48 PM
The bulb is good?? ... recheck to make sure voltage is present at the socket (use a voltmeter). Also check the wiring for the socket to make sure it sees a good ground ...
Old Apr 4, 2009 | 12:22 AM
alex_0227's Avatar
where would the blink control unit be located? Is st behind the radio? The socket seems to have power, but its steady, doesnt flash.
________
Vermont medical marijuana dispensaries
Old Apr 4, 2009 | 02:18 AM
I don't mean to be downplaying your problem, but you do realize that Saturns have a three-bulb light system ... Please check again, as it sounds like you are looking at the running light for the tail light system rather than the turn signal light.
Arrgghhhh .... I didn't explain that right. There are three bulbs in the taillight housing: one that does double duty as a running light (at night), and the stop light function, a separate bulb for the turn signal function, and the third one for the back-up light. Make sure you check the correct bulb ...
Last edited by OceanArcher; Apr 4, 2009 at 09:39 AM. Reason: Attempt to clarify my explaination ...
Old Apr 4, 2009 | 09:58 AM
It not what you call the blink control unit, correct name is "turn signal flasher".
redvue
Dec 2, 2011 11:19 AM
LmyVue
Oct 9, 2008 10:23 AM
WiShJ1
Apr 5, 2007 03:02 PM
Murrieta2003
Nov 29, 2006 01:48 AM
elkslayer69
Sep 29, 2005 06:25 AM
