98 saturn sl with bad motor shake
Old Jan 7, 2010 | 11:40 AM
tonygarcia1990's Avatar
Default 98 saturn sl with bad motor shake
at idle i am getting a bad motor vibration. but while driving the car is fine. I did a turn up and did a fuel injection clean nothing changed. I think it might be the motor mounts but idk? If i put my hand on the intake manifold i rock the motor back and forth. i can see the top motor mount but it looks fine where is the lower motor mount and how do u change it ? thanks for your help
Old Jan 7, 2010 | 12:25 PM
Maybe your talking about a SATURN SL,SL1,or SL2. If so sounds like your top engine mount
Old Jan 7, 2010 | 04:42 PM
yes sorry its a saturn sl
Old Jan 7, 2010 | 09:04 PM
top engine mount (torque axis mount) is a wear and tear item on these s cars. Support the engine from underneath (floor jack + wood to avoid point force and oil pan damage) to take the stress off the upper mount. Remove the three nuts on the studs going through the mount and the two nuts that hold the mount bracket to the car.
Replace with new upper mount. Be sure to use new studs and nuts.
If this does not address the vibe, we'll look deeper.
Old Jan 7, 2010 | 09:08 PM
thanks alot I will let you guys know
Daddi0
Jul 28, 2011 07:21 AM
tonygarcia1990
Jan 19, 2010 12:01 PM
99 Saturn SL2
Aug 10, 2009 10:19 PM
Secretagent0057
Jun 9, 2008 04:28 PM
geramos
Jul 20, 2007 03:56 PM
